dBpowerAMP Music Converter (dMC) |
- A raft of DSP effects - fade, adaptive volume normalize, silence trim, karaoke, reverse,
sound grabber and many other DSP effects,
- Set encoding Priority level (time slice priority Windows gives dMC),
- Option to automatically shut down computer after conversion
- Skip Conversion complete message,
- Play sound after conversion,
- Run a program / script before and after conversion,
- Exclude individual files from Playlist Conversions,
- Fun Bars - changes the Percentage bar between many
excellent designs, details
and Fun Bar Pack install:
dMC Audio CD Input |
dMC Auxiliary Input |
- Auto Trim silence and Preserve audio during auto start and auto end
recording,
- Smart Track Length - if recording with Auto Start
and Auto End, STL enhances dMCs ability to determine end of
track silences. Also if recording manually, STL can be set
to record for a set time per track.
- Auto create playlists (M3U, or PLS),
- Listen to recorded Sounds
